Page 24 of 109
Re: Torbo2s Duett
Posted: Fri 21 Dec 2012 12:28
En tilbakesporing til dreiebenk.
Markedet for brukte kvalitetsbenker er relativt beskjedent i Noreg.
Hvordan er utvalget i f.eks USA?
Kanskje ikke regnestykket blir så galt, frakten tatt i betraktning?
Re: Torbo2s Duett
Posted: Fri 21 Dec 2012 12:33
by hlyshaug
Re: Torbo2s Duett
Posted: Fri 21 Dec 2012 12:42
Akkurat den bilen er jo UR-bra!
Re: Torbo2s Duett
Posted: Fri 21 Dec 2012 18:56
Suverent! Man pass nå på hunden!
Re: Torbo2s Duett
Posted: Fri 21 Dec 2012 19:06
by hlyshaug
Observert i Stangebyen nå onsdag. Stange er et oppkomme av middelaldrende japanere...
Akkurat denne kan gjerne pakkes inn og legges under juletreet mitt. Riktig farge for høytiden, til og med.
Re: Torbo2s Duett
Posted: Fri 21 Dec 2012 23:36
by lukeball
In the U.S. there is a large market for used equipment. The reason being that most new stuff is CNC and very expensive. We have a large Mazak CNC lathe at work that cost almost $250,000 new. Most used equipment keeps its valve however. My lathe cost $950 and I invested about another $200 rebuilding, buying tooling, and other accessories. It is 228 x 1220mm. My next lathe will be much larger. I would like a 381 x 1270mm Colchester. Colchester lathes from the 1980s that are in good condition sell for about $8500. I buy most of my used equipment from
http://www.industrialmachinery.com/store/ They are not very far from my house.
I like the Volvo Sugga, but they are very rare and expensive. The Redbull one doesn't retain much Volvo and it was built on a GMC chassis. Here are a few nice ones in your price range:
http://www.blocket.se/dalarna/Volvo_Sug ... ca=1_8&w=3
http://www.blocket.se/sodermanland/Volv ... ca=1_8&w=3
http://www.blocket.se/gavleborg/Volvo_P ... ca=1_8&w=3
http://www.blocket.se/vasternorrland/Do ... w=3&last=1 Looks rough
Re: Torbo2s Duett
Posted: Fri 21 Dec 2012 23:48
That could be something...
viewtopic.php?f=28&t=1062&start=345
May be to much work?
About lathe, the marked of used very little in Norway. So it will probably by a new one.
but i also checks blocket in Sweden.
To heavy to ship from USA I think?
Thanks!
Re: Torbo2s Duett
Posted: Sat 22 Dec 2012 01:41
by lukeball
The lathes that you listed look fairly good for the price. This one is best:
http://www.gasolin.no/index.php?main_pa ... cts_id=693 It has higher speed and a larger 25mm spindle. My best suggestion is looking at it in person. Test the feel of the components. These lathes are not expensive for something new. Are they made in China? Stuff like this can last, if it is taken care of, but sometimes the components can wear out sooner. That is why I went with an older lathe. This stuff does look like quality.
This is what I am talking about and fairly cheap also
http://www.blocket.se/pitea/Svarv_Brode ... ca=1_8&w=3 This kind of stuff has to exist in Norway. Just look in the classifieds section of the newspaper or online.
Re: Torbo2s Duett
Posted: Sat 22 Dec 2012 02:01
That looks good, but it is two big present me I think?
Nearly everything is make in China so Im not worried about that. And bearing much standard, here I heard.
I'd like a large and more stable, but then I move to the country first ..
It is the most chores I'll use it then it will become one with enough length 550 and 225 chuck?
May be to the price of 10900 kroner...
Re: Torbo2s Duett
Posted: Sat 22 Dec 2012 02:07
That looks good, but it is two big present may I think?
Nearly everything is make in China now, so Im not worried about that. And bearing are much standard, have I heard.
I'd like a large and more stable, but then I have to move to the country first ..
http://www.gasolin.no/index.php?main_pa ... s_id=12199
Re: Torbo2s Duett
Posted: Sat 22 Dec 2012 02:52
by lukeball
It is really up to you what you choose. I am completely satisfied with mine. I try to avoid chinese stuff and very few of my tools are made in china. A 225mm chuck is sufficient; the chuck size depends on the swing of the lathe. I get a larger lathe just to do brakes, flywheels and larger parts. Most of my parts are small and short, but I have also threaded a 1m rod before.
Last point to pay attention to: most of these lathes thread in either metric or standard. Mine does only standard. You need other gears to change it around. Volvo uses standard threads and there is a lot of metric stuff. Just take that into account. I am not sure how much threading you would do, but it is nice sometimes. Acme threads are really nice.
Also, these lathes don't turn fast enough for carbide cutting tools. You can use them, but the finish is not very good. I use HSS. You can buy pre-ground ones or grind your own. HSS insert is really nice. These are a little expensive, but I am buying some soon. Quality cutting tools make all the difference.
http://www.arwarnerco.com/c-5-tool-kits.aspx
Re: Torbo2s Duett
Posted: Sat 22 Dec 2012 10:38
Interesting! I also like HSS, I seems to remember that the cut vas exielent, rather than hardmetal? But mutch has may be happen since I do al lot of thing in lathe..
It should be good to make drums, but this means a bigger lathe I think?
I think hlyshaugs lifters is make by hardmetal and vas very bad for an nice isky-cam!
Have you seen somthing worse?
I have nerver seen worse surface in some engine! Baaaaaaad!
If We had time we should go back and ask them some qouestions? Ant take a fight? But sine we are primary "peacefull" we did not do that, and/also since you had some good ones to hlyshaug.
It is may be in the middle of the night "over there" now, so you may not reading this for a while...
Re: Torbo2s Duett
Posted: Mon 24 Dec 2012 05:02
by lukeball
They set the feed rate too fasting and took too deep of a cut at one pass. That is rookie's work. Those could be cleaned up, but maybe have to remove .5mm. I would try the slowest feed rate of 0.05mm/revolution. An even better option is finding a grinder that can mount on the cross-feed.
Re: Torbo2s Duett
Posted: Mon 24 Dec 2012 12:07
Thanks for info!
Nice machine also...
Merry Christmas!
Re: Torbo2s Duett
Posted: Mon 24 Dec 2012 12:33
lukeball wrote:That is rookie's work.
Det var vel det vi også var inne på. Her må det ha vært en lærling på villspor, uten kyndig veiledning.
