It depends on what you want to achieve, some will have better driveability, someone will have the horsepower and tune up.
I`m not spesialist, butI have higher education in the motor and the combustion technique, experience and so on.
So I would think that this isky-comb can work well. Unless we adjust the cam 2-4 degrees for better torque around 2000 rev / min.
We will also increase compression slightly, for about 8:1 - 8,5:1
But I would rather have the solutions C-, D- and K-cam provides
Note the lobe separation. During 105 to 108 degrees will go bad idle below 1200 r / min.
I used the R-cam for a while (102 degrees), but it was useless in city driving. Now I use D-cam from Volvo, the same as K-cam about. It provides plenty of power, and idle ok.
I have set it up 2 degrees in order to get more power from 2000 rev / min.
Otherwise it is mostly said in this article.
We are talking about tvo engines here. Hlyshaug will have a smooth and strong engine, B16, and the Swedish guy will have most power on B20.
Her is also a good place for good cams:
http://www.kgtrimning.com/
The Swedish guy will have some other
http://amazon.forum.bilia.se/phpbb3/vie ... 489#p95489
